hi all,
just installed a new 8 way wylex rcd board for a friend turned on the circuits everything was fine, started to plug appliances in one by one and firstly when the fridge is plugged in it trips the 100a 30ma main rcd switch, i thought it was a faulty fridge, i left the fridge unplugged for 20 mins then when i plugged it back in the rcd stayed on, its tripped off twice since in the last 6 days always turning back on with the fridge unplugged, left out for a while then plugged back in. secondly when the mira sprint 8.5kw shower is turned on this also trips the rcd. i managed to get the shower running with power on but just on cold water setting as soon as power is turned up rcd trips!!! i told my mate he had a faulty fridge and shower (bit of bad luck) my mate decided to put up with the fridge but has gone straight out bought a brand new replacement mira sprint 8.5kw had it fitted an hour ago and he's just rang and told me the very same thing is happening!? at the min im feeling like quite a bad mate!! so has anyone got any ideas please i have tried ringing mira and wylex tech support but cant get thru. any help would be very appreiciated
