Hi all,
Just wanted to check what might be the issue with my electric shower before I pay to have a bew one installed.
Basically, the water shuts off after about 5 minutes if showering. The shower still has power (lights on) and occasionally the water then immediately restarts before cutting out again after a second or two. This happens when running cold water and I have tried running it without the shower head and it still does it. Leaving the shower for a while makes it usuable again.
Strangely, it also seems to turn itself off even if the water isn't actually running- sometimes 20 seconds or so after manually turning the shower water off before it has cut out, I hear the shower unit make a click sound and then if I try to run the shower then no water will come out.
All of the above makes me think it isn't some kind of overheating problem, and I don't know why it would turn the water off when the water isn't actually running.
I've literally got a new shower waiting to be installed, but wanted to check it isn't something obviously wrong such as pressure issues before I spend the time and money instalking a new one just for that to also have problems.
Thanks in advance.
Thanks in advance.
