Electric shower
25 Nov 2007
Gloucestershire
Hi all,
When i pull the isolator switch on the ceiling the red power light comes on.
However, when i then turn the shower on, nothing happens and the red power light on the isolator goes off.
When i turn the shower switch to off the red power light then comes back on.
Anybody got any ideas please?
The shower is a Triton Seville
Loose neutral somewhere by the sounds of it.
Check consumer unit, switch and showerl
As said you have a bad connection more likely the pullcord check the pullcord for burnt damaged/loose connections.
Thankyou for your replies.
I have looked in the shower and the isolator and all seems tight and in good condition.
I am not going anywhere near the consumer unit, though there is no reason anything should be wrong with this as nobody goes into the cupboard where it is. I have checked the trip and it is working perfectly
Do you think it worth changing the pull cord before calling in reinforcements?
Don't need to go near it to cause a bad or loose connection.
Yes worth changing pullcord it's useally the pullcord that fails.
Check it with a multi meter when it fails, if you have 230v supply and low or no reading on the load the pullcords failed.
