Hi Guys and Gals,
Something that always keeps me guessing is the relationship between an electric showers KW and whether you get a higher water pressure. I know that the higher KW showers heat the water up quicker but is that where it ends.
Is there a calculation relating the the KW difference for advising as to the difference in pressure if any. Is an 9.5kw 10%(ish) more powerful than an 8.5 for example
Is it really worth upgrading a cable from 6mm to 10mm (plus fuses etc.) and installing a higher KW shower, will the customer notice much of a difference?
Customers often ask me, my electric shower pressure is crap, what can I do. I know there are several options of varying cost and work(i.e. mixers with pump off gravity), but can it be simple matter of upgrading the cable/fuses and shower KW.
There we go, knock yourselves out on the answers folks, hopefully some will match up! l
