hi
When my dimmer is fully dimmed, the filiment can be seen to be flickering. When the light is half way, the light pulses up and down, only a small amount, but enough to make my eyes adjust to the new ligh level over and over... hard to describe.
I thought the dimmer was faulty, so bought another, and moved the suspected device to an upstairs room (different lighting circuit) and now both dimmers flicker.
I have always thought that the problem was the dimmers or the lighting circuits, but tonight i opened the microwave and the bulb in there was also flickering - the kitchen is on a different ring to the lights as it should be, so it cant be the wiring, can it?
The meter tails from the meter to the fuse box are quite long, about 2m in length from floor to ceiling, could it be this?
The lower the light level from the bulb, the move odvious the flicker. As the microwave is a low watt bulb i can see the flicker.
What do i need to do the get this fixed? I cant see how i can fix it?!
