- Joined
- 13 Sep 2015
- Messages
- 114
- Reaction score
- 6
- Country
Hi all,
I'm running electric UFH. (Yes, I know opinions vary about usefulness ... let's just go with it!)
It's a 16m^2 area and I'm using loose cable. I have 2 reels. This means two cold tails.
I know the heating cable itself should not get closer than 50mm but is there any reason I can't bunch the cold tails? To avoid channelling plaster, they'll be routed through a solid block wall to a neighbouring utility room, before going back through the wall to the thermostat.
Based on length of cable, each tail will be carrying around 5.5amps. I have no idea of the CSA of the tail but I assume it's been sized for that load.
Can I run both tails and the tail from the temperature probe in the same 20mm plastic conduit - let's say total length 3 metres - or am I likely to be derating the capacity of the tail unacceptably?
Phill
Phill
