Apologies in advance for the long post, hope someone can advise
We've had our floor tiled a couple of weeks ago. This week we put the underfloor heating on for the first time and gradually increased the temperature by 5 degrees per day
Today we set it to 27 degrees and it has taken 6 hours to get to 20 degrees! starting from cold at 10 degrees!
Currently it is showing as 20.5 degrees but have also noticed it goes to 21 but then drops rather than increasing to the 27 degrees I've set it to Is this normal?
We have 2 mats but one temperature sensor, we've also noticed where the mat is laid on the concrete side it is not as warm as the side where its a timber floor with concrete cement boards
Furthermore on the timber floor side some areas of the floor are considerably warmer than other areas of the same floor!? There are cold spots and lukewarm
Any ideas what could be wrong? Could it be the thermostat/sensor or something else?
