My house just has a small electric water heater. Refitting the kitchen, I've discovered the appliances are fed from the hot supply. Which struck me as odd considering. Presumably more expensive to run that way.
Now I'm wondering whether this was to maintain tap water temp when appliances are in use. As if they're fed from the cold, that would reduce flow and so increase the temp from the heater? Does that sound correct? Or was this just a mistake, the house is a bit of a mess.
Should I switch appliances back to cold feed, which was my initial thought?
