Your answer for question 1, 476, is CORRECT! The correct answer is 476
Your answer for question 2, 43, is CORRECT! The correct answer is 43
Your answer for question 3, 128, is CORRECT! The correct answer is 128
Your answer for question 4, 1542, is CORRECT! The correct answer is 1542
Your answer for question 5, 10,000, is CORRECT! The correct answer is 10,000
Your answer for question 6, 9, is CORRECT! The correct answer is 9
Your answer for question 7, 36.0, is CORRECT! The correct answer is 36.0
Your answer for question 8, 3/4, is CORRECT! The correct answer is 3/4
Your answer for question 9, 3, is CORRECT! The correct answer is 3
Your answer for question 10, 10, is CORRECT! The correct answer is 10
Your answer for question 11, 15, is CORRECT! The correct answer is 15
Your answer for question 12, Remove plug from socket, is CORRECT! The correct answer is Remove plug from socket
You got 12 answers right.
You got answers wrong.
If you did well why not fill in an application form on-line Application Form
If you did not then we would urge you to contact your careers office for further advice
Yeah
