I have a couple of questions: -
1. I want to provide a power feed to an outbuilding on my property. I propose to wire in a ring main from the CU to the outbuilding. I believe that the regs. state a max. floor area of 100sq.m and max. cable length of 50m. Whilst the floor area does not exceed 100sq.m the required cable length is just over the 50m (62m). Does anyone know of a way around this but safe??
2. I have a new combination boiler which loses pressure and I have to recharge it 2-3 times a month, whereas it should only need to be recharged 1-2 time a year. I have discovered a small leak from the boiler. Could this be the only reason for the pressure drop or is there likely to be a further leak in the system.
I would be grateful for some advice from any of you experts out there.
