Electrical certification
29 Aug 2013
I have had a new build and renovation project wired. Everything works fine, but I need certification for building control. What kind of certificate do I need, and where should I get it from?
Appreciate your advice.
Slightly hijacking thread.
On a new build by a developer, is the cert issued by the sparky to the developer or the new home buyer?
By whom?
Checking his thread about the immersion heater, you would assume by him.
In which case I believe you can pay the councils building regs people to test it (though they may be unable to if they can't see all of the cable runs or don't accept that you were qualified to design it).
Normally, you would get a qualified sparky to do the work and certify (assuming they don't turn out to be unable to do so, or if they are able to, actually do).
Sounds like a whole heap of pain and expense awaits.
Ah.
But he did say "I have had a new build and renovation project wired", and not "I have wired a new build and renovation project"
Well let's hope he didn't DIH, as on the basis of the immersion heater topic he's not competent enough.
At this point we really do need to know the answer to this question to be able to give the best advice:
Mission, when you applied for Building Regulations approval for that, what did you say, or allow to be said on your behalf, or tacitly accept via LABC assumptions, would be the way that you would ensure compliance with Part P of the Building Regulations, and did you actually do it that way?
The cert is issued to the client ordering the work, this is generally the owner of the property.
Which, unless the house under construction is 'pre-sold', will presumably be the developer or builder?
Kind Regards, John
I would expect as part of them selling the property to the homebuyer I would expect them to pass on relavent documentation on the property including the aforementioned certificate.
Of course - but that wasn't the question.
Kind Regards, John
John.... Are you and Tony brothers? ;)
I doubt it, since I have no brothers. Tony asked whether the electrician would give the certificate to the developer or the homebuyer. Since I presume (s)he wouldn't give the certificate to a 'prospective homebuyer' (if there was one) before the sale/purchase was completed, I presume that, in most cases, the certificate would initially be given to the developer - who, as you said, should subsequently pass it on to whoever completes a purchase of the property.
Kind Regards, John
If we are my dad did not know, but I am in that position and realised there is no electric cert. :evil:
Mission, ignoring this problem won't make it go away, but it could get a lot worse if you end up with the council simply refusing to give you a completion certificate.
When you applied for Building Regulations approval for the project, what did you say, or allow to be said on your behalf, or tacitly accept via LABC assumptions, would be the way that you would ensure compliance with Part P of the Building Regulations, and did you actually do it that way?
