I've read through the Part P regs and I am just wondering if what I would like to if it is actually notifiable.
I am not proposing to add a new load to an existing circuit, rather reduce.
And the new work is not actually in the kitchen other than replacement of a cable to an existing fused spur.
I wish to remove an existing 13A socket from my kitchen that is on the ring main. At this socket there is also a single 2.5mm cable (a spur off the ring main) running to a switched fused spur, that is also in the kitchen.
I wish to retain the switched fused spur.
What I am proposing to do is remove the 13A socket. Then pull the 2 ring main cables back to a suitable place under the floor. Then run a new 2.5mm cable from the fused spur to this place under the floor and there bring all the 3 cables together in a 30A 3 terminal connector box.
Prior to Part P I would just have "done this"!
Any thoughts would be welcome.
Thank you
MrWhatIf
Thank you
MrWhatIf
