We recently had a new consumer unit fitted by an NICEIC electrician but for some reason despite many phone calls and emails, he did not provide us with a certificate which is required by law. Only after I made a complaint to the NICEIC, did he came back to retest the whole installation and issued us with a certificate and testing schedule.
As part of the testing, he removed the sockets faceplate in our house to check the wiring. All was well until yesterday when we had a had a small electrical fire originating from one of our electrical sockets which melted it and an adapter which was plugged in at the time. It was mostly burnt out but the heat source can be traced to the neutral wire. My guess is that when he pulled the socket out from the wall, he dislodged the neutral wire from the grub screw and was loose which heated up and melted the wire and socket. The neutral terminal broke off but I can see it was loose.
I have spoken to the Niceic who has arranged for an engineer to visit to investigate. My question is should he have checked the tightness of the connections when he removed the socket for inspection as part of the testing? Also, if he was at fault, what will happen to this electrician in question, who was behaving very strangely from the start?
Is £750 reasonable for replacing a 10 way Wylex consumer unit plus a sub unit which contains an RCD and 2 breakers? I was shocked wen he presented the bill but I would like to hear your comment.
