All that information is actually written on the Main switch, and the Type and BS number will vary with the unit installed, and the Fault current will vary with the type as well.
The Main Switch of an Installtion can be a Double Pole Isolator, a Triple Pole Isolator, a TP&N Isolator, a Double Pole RCD, a Double Pole DC sensing RCD, a Double Pole Time Delayed RCD, a Double Pole DC Sensing Time Delayed RCD, a Variable Trip RCD, or one of the three phase varients of the afor mentioned RCD's, not to mention Moulded Case Circuit Breakers (MCCB's) which come in single phase and three phase and in about four different types.
All the above have different BS numbers and fault characteristics. This information MUST LEGALLY be printed on the Unit casing, however the BS numbers for the various tyes are listed in the Regs book.
