Electricity, garage en bloc
29 Dec 2018
Hi all
Basically I have a garage en bloc, o was hoping to add some electricity to, to mostly power a treadmill, cross trainer and abit of lighting if that's at all possible.
Is there an relatively easy way to do this ? My house is near but not next to the garages so I doubt running s line from my house is an option
Someone suggested A car battery, but I'm.not sure if there's alternative options or better options
Mark
My FIL fitted solar panels on the roof of his garage, then used them to trickle charge 2 leisure batteries.
It worked fine to supply power for lighting and electric garage door motor which uses 24v
You would need an inverter to get 240v if thats what the gym equipment uses
Choose equipment that doesn't need electric motors.
Lighting is easy and cheap, but 240v AC at greater currents means the inverter will be expensive. So will the storage batteries.
If it is just to run the display and sensors then the gym equipment may already be 12v and will happily run from a car or leisure battery. Even if its mains only a small invertor may be enough. They are pretty cheap now. Have a look for the power ratings. LED lighting is easy to run from a battery. For charging a solar panel would be nice or just carry the battery back the house once a week, or however often it needs, for charging.
Thanks for all the replies.
I'm abit of a novice, would anyone please link to the things needed at all please? All sounds more hopeful than I first thought,
I know it's probably not going to be cheap, but if it's cheaper than paying £300-400 a year on gym memberships then it's still worth looking into for me I think
Thanks again, very helpful
12 volts generatings about 60 watts ( fit cyclist ) 12 watts ( worn out cyclist )
image from https://bsamuseum.wordpress.com/ww2-pedal-generator-admiralty-pattern-323a/
