I don't know much about electrics and generally avoid, so sorry if this is a bad description.
The junction box (white box on the wall with all the trip switches) keeps tripping. As in, not individual switches but all electrics with the master switch cutting the power to everything. When you reset all seems fine with nothing blown/not working.
It's not happening all the time but has happened about half a dozen times in the past few months. Is usually in the middle of the night when not much is on - the usual stuff on standby, a fridge, a freezer and one light. We also have a mains powered burglar alarm which we don't use but which is "live" (as in the movement detectors have lights which sometimes flash).
It has happened a couple of times in the day also, but seems to be mainly at night. We did have an internal water leak which went undetected for about a month but which was fixed about 3 months ago. I thought that might have been causing it, if water had pooled/tracked along a cable somewhere, but has been fixed for a while now but is still happening. The junction box makes a slight humming noise which you can only hear when the house is completely quiet, but I think this is normal ?
House was built mid 90s and has had no major work done since, as far as I can tell. Any Ideas, is this anything to worry about ?
