- Joined
- 29 Nov 2005
- Messages
- 34
- Reaction score
- 0
- Country
I would like some info please prior to getting someone to carryout work. I am a landlord and the work is in my rental property. The property must be some 25-30 years old. It is two bedroom and there are two 5A lighting fuses in the fusebox. I will get these changed to MCBs
Note that I had the property checked electrically less than 5 years ago when I purchased it..it is due again soon. The electrician knew that the property was to be rented.
Whilst redecorating the bathroom I decided to remove the electrical razor point..dont want any unnecessary electrics in there..there is just a light. So I traced the cable and found that it came from a socket in the loft. So I isolated and pulled out the cable.
I found that socket fed, via twin and earth cable a FSU (3A), for the Central Heating boiler system. Tracing the supply back from the socket I found that it had been taken from a ceiling rose.
I did check the earth continuity between the rose and the FSU and it is ok. However is this legal? It doesn’t sound good to me.
As a now boiler is going in soon I have the opportunity to find another supply. There is a spur available near when the new boiler could go . Can the boiler FSU be spured off that spur. Is there a reg which says how close the Boiler FSU must be to the boiler.
Information much appreciated.
