Aich!
So can anyone provide a link to or quote from the relevant part of the regulations relating to..... whatever heating controls are categorised as..... with respect to bathroom zones?
The regs themselves can be open to interpretation, but the thing is, the IEE regs (17th ed, BS7671 or whatever you want to call them) are not law. They are just a standard - good practice. Part P Building regs may well be law, and may well refer to the IEE regs, but again there can be interpretation, and things are not definitive.
The zone charts mentioned earlier are just convenient things to refer to. The essence is that if you have an electical item in a bathroom then you need to be mindful of the potential to get a shock. Its just common sense really. If you have those items in one of the zones then, it will need suitable protection (IP rating) and potentially low voltage as there is more risk of getting a shock.
If your item is outside the zones, that does not automatically meant that it is safe from water splashes, but there may well be less risk and so less chance of an accident - so you can get away with less protection. Useage of the item is also a factor, and I dare say that you wont be touching those controls regularly or each time you use the bathroom.
So to sum up, in the zones = more proptection needed, outside the zones = less protection needed. Outside the zones and away from potential normal splashing and you can use standard heating controls without any further protection.
You could always go wireless and put the controls where ever you like.
Avoid anything like this
