electrics in bulgaria
2 Sep 2010
iam renovating my property in bulgaria and have noticed that the bulgarian wiring system on a ring main is 2.5 earth .phaze and nutural , iam wondering why do we have 1.5 cable on our earthing system as there cable will surely change my readings,
I'd be surprised if they have a ring final system.
CPC's can be smaller than the live conductors.
However, having a 2.5 cpc is not a problem. It may well be a different reading but so what? just measure and record it.
Because we assume that heavy current will only be carried on the earth wire during a fault, and the fuse/mcb will operate quickly enough that the thinner earth cable won't overheat.
Other countries make different assumptions.
Thanks guys for your help. ive found out that here in bulgaria they dont operate the ring main system everything is on a radial operating about 4 single sockets to a floor so the ratings are about 10 to 20 amps but they have the sockets dropping down from a juntion box about picture height level so if they have a damaged cable they can easily replace it, but to us brits it looks very unsightly so i think i have done the best option in that i have brought uk cable and am installing to uk spec thanks again
The ring final circuit is a peculiarly British thing. Even countries which formerly had close ties with the U.K., such as Australia and New Zealand, have shied away from rings.
It is also very much the norm in Continental Europe these days for the earth conductor to socket outlets to be the same size as the supply conductors.
Not a good idea and almost certainly illegal.
Your insurance could be invalid if there was an electrical fire.
You may have problems when you come to sell.
Best to confirm to the local regs when you go to live in a foreign country.
how can there be a i risk of fire when ive worked to uk spec using the tt method and a qualified electrician and we are working to the best standards in the world and if you was to see how the bulgarian safety standards are then there would be a risk of fire, they have no testing reguirements ,oh wait , iam wrong there if the light comes on when the switch is turned on then its passed
A bit late to the party, I know, but: The Bulgarian regulations are for a two-wire system, phase(live) and neutral. Neutral is tied to earth at the supply posts outside the house, and each socket should have a tiny wire link connecting earth to neutral inside the socket. This way each socket is earthed via the neutral.
Many e-pats, me included, rewire their houses with three-core cable (that awful ribbon cable) running a separate earth circuit back to the distribution board (Hah! two bottle-fuses and some twisted wires :eek: ). That earth circuit still has to be tied to the neutral in the dissy box. The reason the BG earth conductor is 2.5mm is that, in a fault condition, it has to carry enough current to blow the radial circuit fuse, the same current that the neutral conductor would carry if it was wired 2-core.
There is an inspection and certification system, which is supposed to be compulsory for new builds and renovations, but if you don't ask for it, the authorities won't come looking. However, an ex-pat friend rewired his renovation 3-core, ring mains, split load box, three pin plugs, the lot, then was daft enough to ask for an inspection. EVN (the supplier) condemned it on the spot, withdrew his supply and refused to reconnect until it was redone to BG regs. Why: because a BG electrician coming to service, faultfind, whatever, expects the system to be wired to the local regs, however inferior they may be.
I'm in the South East, Near Elhovo, EVN is my supplier, others eON etc may not have the certification system.
Hi Thanks for the reply, it was very interesting even thou you say a little late in comming,but hay we are in bulgaria and what cant get done today will always wait untill tomorrow,the catch being, will tomorrow ever arrive
That's not a catch, it's a benefit, and one of the reasons I love Bulgaria: No nanny state, 100 percent responsible for your own actions, cock-up? it's your own fault, no one to blame but yourself.
I'm also late to the party but I have to echo Karona's sentiments.
I'm in the process of renovating a house (in France, not Bulgaria) and I'm currently doing the plumbing using French tube/fittings etc.
A friend asked me to cast an eye ove their prospective purchase, which had been plumbed by a Brit using UK fittings/systems etc. Any French plumber arriving to resolve a fault would have to start a complete re-plumbing excercise.
Why RH , they aren't that different ? Unless you mean he used imperial-sized fittings ( do they still exist for smaller domestic pipes )
