Hoping someone can help... amongst several other problems I'm having in my flat (which was built only a year ago) is that I've gone through 11 lightbulbs since I moved in 6 months ago; they blow when the lights are turned on. Obviously not every time a light is switched on, but they've never blown after the light's been on for a while, it's always within a fraction of a second of turning them on. It's not isolated to any one room, and it's happened with various types of bulbs (regular pendant bulbs, candle type bulbs in wall lights and also spotlights which, I think, have some sort of transformer attached to them).
My knowledge of electrics stretches to replacing a bulb, frankly, and the builder had been blaming it on the supply coming into the property. I had the supplier come out (Scottish Power) to check that the power coming in was within tolerance. It wasn't, it was running anywhere between 245 and 259v, so they adjusted whatever it was that needed adjusting, and it's now within tolerance. I've since bought a UPS for my computer and it shows that it's now running between 240 and 250v.
The blowing lightbulb saga continued though, and it's not the only symptom. Even with nothing else switched on in the flat (well, apart from the fridge/freezer and boiler, I suppose) the lights can sometimes dim for a tiny fraction of a second. Blink and you'd miss it, you'd barely notice it if you weren't really paying attention. It seems to happen randomly and is apparently unrelated to anything else... although when I switch the vacuum cleaner on, it can almost be made to happen on command. None of this happened in my old flat, although the difference was it was in a building that was over 100 years old and the electrics, whilst not quite as old as that, certainly had a fair few years under their belt.
I went back to the builder again and his final word on the matter was to give me a copy of the electrical compliance certificate for the flat. Except, it wasn't for my flat, it was for the flat downstairs because he couldn't find the one for my flat.
Just last week, coincidentally, I happened to be painting a wall in one of the rooms and unscrewed the light switch from the wall so as not to get paint on it. This is what I found...
I've said it before, my knowledge of electrics is shockingly (ahem) bad but, I wouldn't have expected to find 3 sets of live, neutral and earth going into a single light switch (which controls a single bulb). Or for 3 brown wires to be going into the switch. Or for a choc block thing in there. This is, after all, a brand new building.
Is this normal? If not, and this standard of work is common throughout the flat, could this be the cause of many a dead lightbulb and randomly dimming lights?
Any advice, comments or suggestions gratefully received.
Thanks,
Graeme
Thanks,
Graeme
