Hello
Firstly I know that the work I am proposing here is Part P notifiable. For now I just want to come up with an acceptable plan.
I live in a maisonette and have built a small lean-to (brick, block and slate roof) on a concrete slab, with DPM/DPC etc (so in that respect it is like a small shed).
Electrically it will contain
- a couple of power sockets, on a 2.5mm T&E radial circuit - supplying small power tools (as well as low voltage decking lights). A future owner might stick in a fridge but that is about all that would fit in it.
- a single florescent light and a couple of external security lights (all switched internally) on a 1mm T&E radial circuit.
The house CU is fully populated, MCB only, has no RCD protection and is TN-S earthed. As such I am proposing to run a spur from the existing 32A MCB protected ring (which itself only powers a few sockets at the back part of my maisonette) using a FCU into a new garage-style CU located in the lean-to. The garage-style CU comes with a 40A 30mA RCD as well as a 6A and 32A MCB (and an extra space that will be left blank that accepts single pole RCBOs).
Unfortunately the fused spur (submain?) needs to run externally for approx 6m to get to the lean to, under some raised decking (which is being installed at the same time). I was hoping I could just use 2.5mm T&E cable for this run (as I have loads spare), directly clipped to the decking sub-frame joists where no rodents will be able to chew the wire / no sunlight will be able to degrade the wire. Another advantage is that I don’t have to use external adapter boxes outside to go from 2.5mm T&E to SWA and vice-versa.
I was wondering if anyone could help me answer some questions:
- Is my plan sound? I need to work out that the loading is ok on all the components, but I don’t mind if there is no discrimination in the lean-to itself (if the CU as a whole flips) so long as it doesn’t end up activating the MCB in the house?
- Should I buy a 16A MCB for the new CU (and chuck out the bundled 32A MCB) as the power sockets are being installed radially not ring, or is this not a concern?
- Do the regulations allow for 2.5mm T&E cable externally or must I go SWA?
- What rating FCU should I be looking at using?
- Should I up the lighting wire to 1.5mm?
Thanks everyone for taking time to read this 
