electrics
17 May 2004
hi i have a cable which has yellw/green earth and 2 black cables could you tell me what the 2 black are
Most probably SY, YY or CY control cable, do a search on rswww.com. it is generally only used for industrial applications, SY and CY have a steel braid for mech protection CY does not
crystal ball, if you want to ammend a post do not post again, clcik the
button
Gail - if this cable is installed and in use, can't you tell what the two black cores are used for?
If it's not installed and in use, what application did you have in mind where it wouldn't matter that you have 2 black cores?
And are the current carrying capacity of the conductors and the voltage rating of the insulation suitable for this application?
