The model number doesn't tie up with the PNC number, so you need check them again. If the bulbs are fitted correctly & the wiring is good I would suspect a faulty push button first (easy to check with a multimeter). A new push button would cost you around 10 pounds. Spares available here http://www.electrolux.co.uk/node303...2121553&model=EFC950X/GB&prod_no=&model_type=
