Hi all.
After being switched on for a few minutes the oven trips the circuit breaker in the house fuse box. I've disconnected various components inside the ovento try and see if I can stop it from tripping the RCD. Disconnecting the elements didn't have any effect but when the oven fan motor was disconnected the oven stayed on.
Before I order a new one, is it a safe assumption that the motor is the problem, or could disconnecting it also disable some other component on, say, the main PCB that could be the faulty bit?
Thanks,
Ewan
Thanks,
Ewan
