Hello if I want to wire up 3 mains smoke alarms (interconnected) would I use 1mm 3 core and earth and a separate 3A MCB? I'm thinking I'd rather connect the smoke alarms to the landing ceiling rose that way if the smoke alarms lose supply I'll know because the lights will go out. Is it okay to go 1mm twin from ceiling rose to first SA 1mm 3 core to 2nd SA 1mm 3 core to 3rd SA (i.e serial from bottom floor to top)
Also would I wire emergency non maintained luminaires to any nearby ceiling rose using 1mm 2 core and e (do they automatically detect loss of supply) and can I run 1mm 2 core and e to an existing lightswitch from luminaire so that if I wanted a key switch in future it would be quite simple (knock out another switch box next to existing lightswitch) any help greatly appreciated pleeeeeese
