Guys - completing a cosmetic refurb to an en-suite - flooring and tiling, new shower etc. Faced the not-so-unusual issue of the existing tiles bonded to adhesive/board and coming away on removal to the extent that it is not repairable, and I will have to re-board.
I would usually use Aquapanel onto stud frame and fully W/P with tape & joint sealer, but looking at the surface wall construction, it appears to be dotted & dabbed onto the rear plasterboard wall, with only 1-2cm separating the boards. No room to stud - see image. Can see the rear boards are tacked to wooden stud - will reveal more with rip-out.
Think that I should replace board via dot & dab, and then tank to seal before over-tiling. Any other brighter ideas?? Thanks
View media item 59432 View media item 59433
