Feast your eyes upon these!
I went to my loft earlier to plan a potential satellite cable run and was looking for the top of the wall which separates my bedroom from the en suite.
After lifting a couple of bits of insulation, I found THIS!
View media item 25052 View media item 25054
Basically, in our en suite we have 3 downlights fed off the 12V transformer (I assume!) and a ceiling extractor fan above the shower. Both are switched via a double switch in the bedroom on aforementioned wall.
The two white wires in the pic below seem to go down inside the wall and into the switch. (but have no earths connected)
The grey wire running top to bottom I THINK goes down into a single plug socket, which I believe to be on the upstairs ring main, I haven't checked it. I thought this was a simple spur until I saw the other grey wire running across the picture. Can't work out exactly where this goes, but it is heading for another bedroom.
View media item 25056
Surely the wires shouldn't have been left like that?
(This work was done/ requested by the previous owners. It surprises me because they provided receipts for a lot of the work they had done for them)
Although this is in the loft, it is for appliances in an en suite, so I guess getting it sorted means going for a competent person?
At some point I might need a socket or 2 in the loft for a distribution amp.
Do you think these will be able to come off of the grey ring main / spur wire?
I also want to add a couple of strip lights. Can these be taken from the lighting circuit?
