A lot of the imported ones are not that good, for best I use Dormer ones but they are quite expensive. I get them from J&L though not all the dormer stuff is listed in the catalogue, look at the virtual catalogue as its easier to follow
I have bought some from hong kong, same guy that sells the diamond coated hole saws that I us efor work, he only has a limited range of sizes but its worth getting a few for general use as they are so cheap. He also sells on e-bay. They are better than some of the imported ones that I have bought from the model engineering suppliers
Slot drills are also worth getting as you can plunge cut with these unlike end mills which have to enter from the end of the slot.
Did you get your lathe in the end? if so, what are you upto with it?
