alig31 said:I am wiring the detectors, one to each zone. There are shunt resistors supplied, although the 2 resistors are different; a 10K and a 22K. Could someone draw another diagram showing how 2 detectors are connected together and to the control panel showing the resistors or explain more fully. ( I can add to this)
I am wiring each detector with a 6 core cable. I am happy with the two supply cables, it is the wiring of the other 4 (blue/yellow tamper and white green alarm) and how they interlink. On the control panel there are 2 terminals for each zone and there is a further 2 terminals for the tamper. There is a tamper link supplied across the tamper terminals and the instruction book says with EOL operation the tamper link would usually be left in place. I understand the diagram left by Lectrician (many thanks). I don't understand how the detectors are connected together. I gather the resistors get hard wired into the control panel terminals and are connected across the terminals of the last detector in the line?
