Climate change: Ban all gas boilers from 2025 to reach net-zero
https://www.bbc.co.uk/news/science-environment-57149059
I thought the idea was to ban natural gas boilers, to be replaced by hydrogen boilers, heat pumps, electric heating, or something else. Wouldn't need much retraining for GSR guys to work on hydrogen.Climate change: Ban all gas boilers from 2025 to reach net-zero
Are they having the foresight to use plastic which is not porous to hydrogen?The optimum solution is to continue upgrading the gas network with plastic pipe,
No doubt some kit would need replacing. I think steel and copper pipes would be OK, maybe not all plastics. Not sure whether the thinking is that boilers would need replacing, or perhaps some models can be modded for hydrogen. That's if it happens.Would the network even cope with hydrogen? I was under the impression that hydrogen molecules were smaller than natural gas, so more likely to leak out.
I can see a U turn coming up once reality hits. But we shall see.
reckons their the dogs danglies and can be fitted anywhere as long as its got filled cavity walls.
I knew thatI was being sarcastic
