end panel on wall units
21 Nov 2019
I am going to fit my kitchen tomorrow but I have a question about end panels on one side of my 90 cm cooker is a 15cm wine unit with no doors on it on the other is a 15cm with pull out and a normal 40cm wall unit do I put the end panel flush to the edge of the wall unit with no door and will this make it look odd
Can you not replace the side panel on the wine unit with the end panel - that's what I did with mine.
I can't visualise that. Can you post a pic or sketch?
I meant a sketch of your layout to illustrate the problem
You might even be able to copy and paste a pic from the other website. I can't see the site due to tight security settings.
