I've recently been sent a Smartpower energy monitor but the sensor doesn't fit round the tails!
The set up is Meter --> 100amp isolator --> 3 meter lengths of tail --> C.U.
I can't connect it to the meter tails pre isolator as thats enclosed in a clear plastic electricity board fitted box. . . Past the isolator the long tails to the CU are pretty thick and the sensor wont clip round this.
My question is: Could i trim some of the grey sheath off the tails post isolator so i can clip the sensor on below that? Or would that not leave enough insulation and be overly dangerous.
Any other suggestions? Could i ask the electricity board to remove their plastic case so i can attach the sensor to the thinner insulated meter tails?
