Enforcer 10 and Delta Bell Plus Tamper Circuit
8 Mar 2020
Good Morning,
I have a customer Panel enforcer 10 and Delta bell Plus, the Delta bell has the 2.2K Resistor in the tamper circuit. In the panel the return would normally go to Z33 programmed as tamper this is disconnected because the Z33 and Z34 are configured as Wired zones and set to Intruder, the PGM connection is also use for engineering hold off and set to 59 so where would I put the tamper return for the Delta bell for the tamper to function correctly.
one other quick query can you fit the lightbox cover in the delta bell plus cover..
Many Thanks
Bill
You can’t ....
And yes but you have to modify the light box and it will be lit 24/7
Sparky many thanks for the promo reply, looks like it needs an expander for extra outs to sole the problem. Could you elaborate a bit more on the light box mods you mentioned as I have neve seen the light box
Many thanks
Bill
