Enforcer Alarm - App
11 Feb 2016
Hello,
I have the HomeControl + alarm installed with the LAN module. All is working fine. System is polling on pyronix cloud. I installed the app which connects to my system but then a message appears saying Pyronixcloud has sent a disconnect.
Tried speaking to Pyronix who wouldn't speak to me about the issue and said they would need to speak to my installer.
Anybody else had this issue? It seems like an issue with the cloud itself...
Hello, can anyone help me here. I have the same issue. My app says 'PyronixCloud has sent disconnect'.
I have the latest V10 with the wifi module.
Hello All. Just sorted it. The reason it wasn't connecting was because I needed to enter the correct code which is the code used to arm/disarm system on the control panel. Also the app password is the one I set on the control panel. All sorted now!!! I've gained access. Phew :)
Same problem but with euro 46 app
So I have been using the engineer code to disarm it will try the use code
Mark
Mark
If an alarm is turned ON by its owner with his code an ENGINEER CODE should NOT be able to turn it off.
Think about it.
Time to sort your code/s out I think, change them all and start again.
Engineer codes are able to turn alarm ON, BUT NOT OFF (can only turn OFF, when turned ON with Eng. code, NOT by the user code
Yer I did think that but just playing at the moment not installed it all yet. No bell box or sensors yet.
Mark
