enforcer v10 - big mess up - i need help (reset device, need to repair/zones)
4 May 2019
i had an electrician fit in my v10 (now dissapeared, now im left with a device that doesnt work)
problem is i had my door changes which has the door sensor and this was bringing a tamper alert, i stupidly did a reset of the device and i have lost all pairings of my motion sensor/door sensor/bell box - and i am confused on how i repair (i know how to learn devices on different inputs, well i did that via the button when you unscrew the motion sensor and it did says it 'learn the device'
this is what i want help on please, this is similar to the previous set up...
i have 4 motion sensors
1 x kitchen
1 x lounge
1 x upstairs hallway
1 x bedroom
1 x door sensor
1 x bellbox
(i want two zones, (A) 1 zone which sets the whole house and another zone which sets downstairs only (B)
i don't want the annoying chime when you open and close the front door.
is this something i can do DIY, or would i need to find an electrician to assist? because i imagine you would need a ladder to resync the bellbox right?
appreciate your help
thanks
it looks like my door sensor is damaged, i cant open the device - screw seems damaged so i can't repair and the backplate is broken slightly (i had my door changed)
i have managed to pair my 4 pir motion sensors again all set for (zone A) kitchen, lounge, upstairs landing, bedroom - will add my front door (awaiting replacement sensor)
I want to also set a night alarm (Zone b for downstairs which would be (kitchen) (lounge) (and front door (awaiting replacement sensor) is it a simple process to create a zone b? my questions are going forward.
1) i am going to order a new door sensor - is this quite straight forward to install? this would need to be configured as part of zone a and zone b
2) my bellbox is also not on the panel and needs repairing, do i need to get a ladder and resync or is there an easier way? does this have a similar pairing button that is found on the sensors which i press to sync, but i use learning devices bell option on the enforcer settngs right?
3) if i buy a Pyronix Enforcer Keyfob-WE - does this only work within the proximity of my home? I would just want to use this to set alarm/disarm, set zone a, set zone b, and panic alarm...
thank you
