re the above posts.
EGR has absolutely nothing to do with warming the car up. the recirculation ( or reburn) of exhaust gasses is solely to LOWER exhaust gas temperature, hence lower the output of NOx (oxides of nitrogen, the smog creating gas)
anyhow, lesson aside, you can blank the valve off. however this model (and most vauxhalls) have a valve position feedback sensor incorperated. if the valve is sticking, which i suspect yours is, (common fault), then blanking the valve off will still put on the check engine light.
replacement valve is, unfortunately, the only cure. what oil do you use in the car? this, believe it or not, is largely the thing that contributes to EGR valve failure.
in short, blank it off and live with the light, or replace the valve.
dave
