Engine temp
14 Mar 2008
How hot does the thermostat housing and engine get on a 1.3 fiesta in degrees C? Just sealing housing as still leaking
It'll be at least as hot at the temp that's stamped on the thermostat or the box it came in. So if it opens at say 98°C then it'll get as high as that and maybe even higher.
Cooling systems are pressurised to increase the boiling point of the coolant, so the temperature could easily exceed 100 degrees centigrade.
IIRC a radiator cap incorporating a 13 PSI pressure relief valve will not allow the system to boil until the temperature reaches about 125 C.
That's what makes releasing the radiator cap on a hot engine dangerous - once the pressure is released, the coolant, which may be above it's boiling point at atmospheric pressure instantly boils, blowing hot coolant out over anything (and anyone) in it's way.
