Hi everyone. I'm new to this forum but i've came across a lot of very useful discussions while doing some research which prompted me to sign up!
So i've recently bought a 1970s house that needs some work done, we are about to get an electrician to rewire the entire house and after that's done I want to get started with the floors. The floors used to be carpets on a suspended floor, before we got the house the carpets got removed and the subfloor that's left has been butchered over the years.
The plan so far is to remove all the old boards on the ground floor (~60sqm), clean the ground below to make sure we have nice air circulation, insulate with 75mm celotex and put the new floor.
The question I have is regarding the new floor; Originally we were considering putting some hardwood floor, but reading online it looks like in Scotland with the overall humidity putting down engineered floors might be a better idea which i'm fine with. After some looking around we are thinking of going for **** (not sure if links are allowed?) which looks nice but I think the dimensions might be a bit of an issue.
I've seen conflicting information but it looks like the consensus is that the joint between boards should be over a joist. The issue with that is the boards in those packs are mixed and can be as short as 30cm when my joist are 45cm between centres. So I'm looking for some advice if possible:
- Should I put a subfloor of plywood/chipboard and place the boards on top? I'm worried this will add quite a bit to the cost and will create a step between rooms. Also it looks like 18mm is the way to go for ply, but 18mm ply + 20mm engineered floor seems a bit overkill
- Should I just find a different source of engineered floor with longer boards? With longer boards close to a a multiple of 45 I should be able to have far less wastage.
- Any other option that i'm missing?
