Hello
I have a hallway which is half cement/screed subfloor and half parquet blocks (is level all the way through, across the two types). Currently carpeted. I want to get rid of the carpet and lay a 15mm engineered oak through the hallway, and am not sure how to fix the engineered floor down.
Do i rip up the parquet and the use 2 inches of screed to bring the height of the floor back up level with the rest of the existing screeded area?
Or is it OK to lay the engineered floor over two very different subfloor types?
Can a engineered floor be half floating (my preferred option) and half secret nailed? (as I assume you cant float the boards over the parquet blocks (I was going to use elastilon - any good?).
I've never laid a floor before - am pretty sure I can do it though. Just want to give it the best shot i can!
Mike
Mike
