I am considering installing a shower, WC and hand basin as an ensuite option in our main bedroom and I am looking for some general advice. Main cold water tank is located in loft above bedroom but hot water tank is on same floor (probably 18 inches below floor level of intended location and is located in another room at opposite end of house, however there is a handbasin with hot & cold water coming into the bedroom where I intend to have the ensuite. Question is can I use this source of hot water for a shower?...and what kind of shower unit would you recommend?
Second question is:- as the soil pipe is located at the other end of the house(as is the main drain) what macerator would you recommend (Sanipro?) - I assume I can just run the pipe work internally under floor boards and join the main soil pipe- assuming drop ratio is within technical spec of unit? Running the pipework externally is somewhat daunting given the route I would have to take.
Cheers Ross )
Cheers Ross )
