I have asked a few questions now about my proposed ensuite on the 2nd storey of my house. I will be getting a plumber in to advise but can you tell me if it is possible to take a feed from the sink on the 1st floor and use this to feed the new on suite on the 2nd floor and the shower etc. I have floor boards so hoping it can routed this way.
The other option would be to have the soil pipe run above the floor against internal wall allowing my to make sure i get the correct fall and i could then box the pipe in. Would this work?
Can the sink and shower waste pipe run under the floor as i assume its smaller pipe dimensions and then join the waste stack on the external wall.
Once outside the waste pipe probably has a distance of around 7m to reach the existing soil pipe as long as this has the correct fall on it i assume its not a problem.
Thanks Lee
Thanks Lee
