Entry/ Exit zones - I need to use PIR - See updated post
28 Feb 2010
Hampshire
As a newbie installing my own alarm I have asked my builder to run in wiring for the system. He told me that with a lot of modern doors being metal framed most installers now use PIR's in place of contacts on front and rear doors?
Is that true?
I don't have problem using PIR's for that purpose as long as they are programmable as entry exit devices.
I always put contacts on front and back doors , that way the alarm will not set with a door open.There are contacts for all kinds of doors , plus you can use the CHIME function with a contact but not with a pir.
Would always recommend at least a contact on the Front (entry) door. But as above is best so you don't leave an external door open, although you might still forget to lock it.
I've had to go for PIR's for the entry exit zones in my new house.
Both the hall and the kitchen will be the entry/exit points. I am wondering if I should use dual (IR + Microwave) detectors in these areas as both will have direct sunlight and heating (radiator in hall and cooking appliances in kitchen).
Any advice appreciated.
Al
Al
I would use a quad pir much more cost effective.
http://www.securitywarehouse.co.uk/...age=product_info&cPath=36_37&products_id=1572
