Entry phone
5 Oct 2010
I wonder if anyone can help me with the following:
Recently our entry phone system started to behave irratically.
The entry phone system serves 6 flats in a 100yr old building and was fitted ages ago.
Today I measured the +/- terminal in the outside unit and indeed there was no voltage.
However, I can't fix this as I can't see where the power is coming from. The supply cable (looks like regular phone cable) disappears into to wall.
What is the common place for the powersupply? Could it be from one of the flats?
It should be in a riser, communal cupboard or main services area (where the feeds for power and services enter the building),
I'd have thought that the entry phone is the freeholders responsibility,
Sorry forgot to say this is a Scottish tennement flat, freehold I think.
Anyway, I'll check the box that serves the stairlights tonight.
Maybe it is hidden in there.
The clue should be a fused spur off the building supply.
Usually just inside the close high up on the wall, beware of the (often very ancient) mains supply wiring.
As said above, your factor should sort this but then again they may be totally useless or ridiculously overpriced, or you may not have one.
