eorosec CPX Battery Problem
31 Oct 2010
West Midlands
I have recently moved into a house with a eorosec CPX based alarm system.
I have checked the log and see that every hour in comes up with "Aux Volts Lo". I am assuming that this means the main battery is on the way out.
If this is correct I am assuming that I can open the case, order a new battery and replace it. Is there any tamper issues I should be aware of?
Assuming the installer has not set engineer reset on tampers, you should be ok.
