- Joined
- 31 Mar 2013
- Messages
- 521
- Reaction score
- 48
- Country
I'm going to replace my garage roof this year with EPDM. Which manufactures of EPDM roofing should I look at and which are the suppliers to go with? Thanks.
didn't quite understand the question; you run the rubber up the wall as far as you like and then flash the metal over the top edge of the rubber and seal the metal into the wall. You don't have to cut the chase into the mortar if you don't want to, though it's easier and perhaps looks better than slotting the brickThe mortar course is 105mm from the boards, is that too close to the rubber? Or should I fit in at the next mortar course?
