I am working out how to attach the mounting brackets for a 2M venetian blind to the upvc frame above the main windows of a small conservatory.
Due to the cheapskate installation, I have discovered that there is no inner steel re-enforcement behind the upvc panel, so I cannot screw the brackets directly to the thin plastic frame.
I propose instead, screwing the mounting brackets to a head board 2M x 4.5 cms, and then attaching the whole structure to the frame using the ‘world’s strongest glue’ J-B Weld Industrial Strength Adhesive, holding it in place during the cure with half a dozen temporary screws.
I have no real idea how much of this epoxy JB Weld I will need. The ‘professional pack’ at £24.99 would be probably too much being 2 x 5oz tubes total 282g. I would like to spend as little as possible, obviously, and the small retail packs of 2 x 1oz tubes total 56g are better value at £4.69 a pop. But how many would I need to adequately coat the 900square cms area of wood?
Anyone know how far a 2oz pack will go?
