Hi all, first post so please be gentle!
I'm hoping someone can help me but if I've posted in he wrong section I'd be grateful if this could be moved.
Right, I've recently built a kennels outside which has a concrete base topped with a screed and coated with epoxy primer and then epoxy coating.
So far the floors been great but yesterday when opening one of the doors a stone got caught under the door and took a gouge out of the floor down to the screed.
The gouge is about 50mm long by 7mm wide and 3mm deep and I'm looking for a repair solution. I can't afford to buy more coating as it's a lot and was thinking of using either epoxy repair mortar or epoxy repair putty. I wash the floor with a pressure washer so it needs to withstand that.
Can anyone tell me if I'm on the right track with either the mortar or putty or suggest an alternative?
Thanks in advance
Thanks in advance
