EPS70 insulation
12 Feb 2015
Surrey
I have excess EPS70 Kay Metzeler 120mm insulation, could I use it in between joists in a flat roof instead of rigid?
Between? Are you venting the roof or putting additional insulation across the top of the joists?
Are you drawing a distinction between 120mm EPS board and rigid board? What do you mean by "rigid"?
Yes, PIR ("rigid") boards have better thermal parameters.
But I was asking if the EPS70 would be appropriate in the flat roof joists for other reasons, as it is made for floors and walls.
It is a cold flat roof, a one story side extension attached to the side of the house below the gables.
The layers are:
"3 layer torch on system with mineral finish"
18mm ply
firrings
150mm joists
There are soffit vents on all 3 sides of this roof for ventilation and due to the firrings many gaps above the joists as well.
Rigidity, to me, is not about thermal performance; it's about structure. I regard EPS boards as "rigid", in contrast to e.g. blown EPS bead which is not rigid..
You can use EPS board in a roof
