I have been reading alot of information provided and believe my circumstance is a bit unusual....heres hoping someone can help??
I have an ex pub which has an unusual layout, we have a water main that enters the house underneath the concrete floor and pops up anywhere that it is needed......we have no internal stopcocks so its out to the street to turn off the water supply.
So heres the question,
Do I have to have send a 10mm cable to each point it pops out the concrete .....if so in 1 conected run or will mulitple runs from the CU be ok?
and the dilemma,
The pipe pops out the ground in the downstairs shower room, assuming it will require a 10mm cable connecting it to the CU and then will require supplementery bonding. According to the 17th edition you must not connect the supplementry bonding back to the CU .........surely thats exactly what you are doing as its a small shower room and all "exposed" pipes are right next to the point the cold feed leaves the concrete and so will be connected together??
Thanks in advance
Any advice appreciated!
and the dilemma,
Thanks in advance
