escort engine transplant
1 Jun 2008
Yorkshire
hi i had to swap engines due to cambelt snapping we decided to put a td in to it as it was only a diesel it is out of a n reg and has gone in a n reg but there is no power to the starter even though it is connected and no power in the diesel pump. the pump on normal engine had only 3 wires to it the new one has 8 can any body help please
injector pump will need swapping for the immobiliser to work, unless you have the old car too in which case you should be able to swap the ignition transponder and engine loom.
Not sure if the injector pumps are the same between turbo and non-turbo engines though :confused:
